Knock sensor on 95 5.0???
Old 02-07-2002, 10:23 PM
fivept0's Avatar
I have a 95 5.0 150 and I'm trying to sort all the problems out with it...as i'm sure you can tell by all my posts anyways...i'm getting a "knock sensor not detected" code or something close to that (I forget what the number is)
Do 5.0s even have knock sensors? I didn't think so, but I could be wrong?? If they do, where is it? I've looked all over and can't find it.
BTW: I have a pinging problem with the truck as well.
Thanks alot,
scott
Old 02-08-2002, 06:57 PM
FORD302GUY's Avatar
Your knock sensor is on the very back of the motor.(right on top of the engine block itself). Trust me it is a major pain to get too,but it is there.
Old 02-08-2002, 07:40 PM
Macgyver's Avatar
i am lookinmg at a picture of componant locations in my book right now and it looks to be under the plenium near the rear of the motor
Old 02-08-2002, 07:46 PM
PKRWUD's Avatar
Before you replace it, make sure you performed the KOER self test correctly. If you failed to reach WOT when prompted, a knock sensor code will come up.
Take care,
-Chris
Old 02-08-2002, 10:47 PM
inski21's Avatar
Check the base time for the pinging.
Old 02-11-2002, 02:01 AM
fivept0's Avatar
Thanks for the help!
-scott
Old 02-17-2002, 01:49 AM
Wino's Avatar
lack of egr flow will cause pinging. but i think pkrwud is right. you need that wot when doing koer. if you dont it will give you that code. and nothing is wrong.
Quick Reply: Knock sensor on 95 5.0???
