Disabling the automatic door lock?
Old 03-22-2002, 03:14 PM
SmokinSVT's Avatar
Is there a way to disable the automatic door lock. You know how evertime you start your truck and put it in gear it locks the doors, well when you get out the passenger side stays locked and that pisses me off when i want to get something out and its locked!! Is there a way to get rid of this?
Old 03-22-2002, 03:16 PM
AggieSVT's Avatar
Yes it can be done. Check the owner's manual. If I remember correctly, it's in there.
Old 03-22-2002, 11:53 PM
slapshot's Avatar
It is in the owners manual. I did that VERY first thing the day I brought it home from the dealer. Gawd do I hate that, I hate being locked in.
Old 08-03-2002, 08:29 PM
rl1219's Avatar
Auto door lock disabling
Could you share what is required to disable the autodoor locks? I bought 2000 used and it didn't come with one. I'm too cheap to buy one. Thanks!
Old 08-03-2002, 09:10 PM
gp's Avatar
gp
gp is offline
the seat belt donger will also get to you .i know you need to wear it but not riding around the farm.that was the next best thing i got rid of.
Old 08-03-2002, 09:16 PM
Bubba Hyde's Avatar
Talking
Sure. From the manual:
Make sure ignition is off and doors are closed. Turn ingition key to ON. Press power door unlock control three times. Turn ignition key from ON to OFF. Press power door unlock control three times. turn ignition key back to ON The horn will chirp. Press the unlock control, then press the lock control. Horn will chirp once if autolock was activated, twice (one short, one long) if autolock was activated. Turn ignition key to OFF. Horn will chirp once to confirm procedure complete.
All above steps must be completed within 30 seconds, or the procedure will fail. If the procedure fails, you must wait 30 seconds before attempting again.
Oh, yeah...I left out the part about spitting three times at the full moon while slinging a dead cat over your head. My bad.
Old 08-03-2002, 10:22 PM
Blown93's Avatar
To each to his own i guess .. I love my door locks..
Blown 93 Lightning
1.83
13.2
103.00
True Blue 2002
Stock excpt bed rug and tint...
1.98
13.44
102.00
Old 08-03-2002, 10:25 PM
Fast Gator's Avatar
me too But then, I have a keypad on my door
Old 08-03-2002, 11:38 PM
SVT_KY's Avatar
Anybody put a keypad on the passenger door?
Old 08-04-2002, 12:49 AM
oh2red's Avatar
SVT_KY: Key pad? Yes Ford did in 2002.
Driver"s door that is.
Old 08-04-2002, 10:06 AM
SVT_KY's Avatar
Many's the time with the autolock enabled that I
walk around the truck to discover I forgot to unlock the
passenger side....
Requires this disable, OR maybe keypadding the
passenger door so I can open over there too....
Just a thought ....
Old 08-04-2002, 11:53 AM
Silver_2000's Avatar
I dont understand the fear of the auto lock
The door opens when you pull the hadnle from the inside whether it is locked or not. The door WONT autolock unless you are moving which means that it wont autolock on you at the gas station.
Of course I added the keypad to my 2000 -
Here is the how to for you guys with older trucks
http://www.svtlightnings.com/svt/howtolinks.htm
Doug
Old 08-04-2002, 12:27 PM
Fast Gator's Avatar
Doug
How bout the old guys with new trucks
Quick Reply: Disabling the automatic door lock?
