Truck shakes when i let out clutch
Old 04-12-2002, 11:40 AM
bob1's Avatar
My 99 4.2 5 speed F-150 shakes and shudders when i let the clutch out. This happens when shifting into first gear from a stop. Could the clutch be going out? I have 30,000 miles on the truck and it is still under warranty.
Old 04-12-2002, 01:36 PM
GreenMonster's Avatar
Do you pull anything heavy? I can't imagine a clutch going out so early. Also, I don't think the clutch is covered under warranty (unless it's a factory defect). "Normal" wear includes tires, wiper blades, clutch, etc... Hopefully it's nothing major.
Old 04-12-2002, 06:58 PM
LBC150's Avatar
ask talleywacker! his clutch went out at about 15k if i remember correctly...but i think he might even use his vehical for racing!?
Old 04-13-2002, 01:23 AM
dcd's Avatar
dcd
dcd is offline
Mine does the same thing. It started at about 70,000 miles and is still doing it at 92,000 miles. I was advised by a local mechanic that it is an indication that the clutch is going out, but that I should wait until it starts slipping in high gears under load (like pulling hills). I am still waiting for it to start slipping!
Old 04-13-2002, 04:31 PM
morsport6's Avatar
Talk to your dealer about this. My next door neighbor had his replaced at 40k by the dealer. Even though it was past warranty period.
Old 04-14-2002, 05:58 AM
Glenn Mc's Avatar
Bob1
A warped clutch plate can cause the shudder that you are describing. This occurs when they have been overheated by excess slipping. Another cause could be oil or grease on the clutch plate, but that usually goes away after a while. If not slipping, you could drive on the clutch a lot longer before replacement, but it sure takes the fun out of it. I have 150,000 kms. on the clutch in my truck and it is still fine, so I would say that 30,000 is early. GlennMc.
Old 04-15-2002, 11:18 PM
bob1's Avatar
Question Truck shudders
I don't tow. That's why i find it unusual the truck shudders. I do drive mainly in the city though and shift frequently. Bob.
Old 04-17-2002, 06:09 PM
jrm1493's Avatar
my roomate has a 91 chevy 4x4 350 5-spd. his clutch does the same thing, and he thinks its the throw-out bearing. it still clamps up nice and dosent slip, but it does shudder like you're describing. he definatly knows his stuff, but he thinks hes even smarter than he is... no clue if he's right or not but hopefully this helps.
his truck has like 190000 miles, but i doubt its the original clutch (the motor isnt original, so i doubt the clutch is). he hasnt changed it but i bet the guy who he got it from did, so no clue how much time the clutch has on it.
also of note - his getrag tranny shifts like twice as good as my mazda which has a tenth of its mileage... thats annoying for sure!
Old 04-20-2002, 06:47 PM
TubaMan's Avatar
for some reason this doesn't supprise me... I had a ranger that couldn't get more than 20,000KM out of a clutch... I let them do one clutch job, then 20,000km later, it died... they said they would do the second one on warranty, they did it then charged me $900.00 for the job, which lasted another 20,000KM... it eventually got to the point i had one of the local race shops do it for $400 (clutch included), and put in a cheap lund, and it lasted a lot longer... i have very little faith in the ford clutches...
I also noticed that the burnt clutch smell went away with the new clutch
Old 04-20-2002, 07:43 PM
kutter752's Avatar
IN THE NEW 5SPDS THEY DONT HAVE SO CALLED THROW OUT BERRINGS THE SLAVE CYLINDER AND THE THROW OUT BERRING ARE THE SAME PIECE..HAD TO HAVE THE SLAVE CYLINDER REPLACED...COST ABOUT 300 FROM LOCAL SHOP......94000 ON FACTORY CLUTCH.....
98 F-150 5 SPD
RC SB
MODS......K&N DROP IN FILTER.....
MORE TO COME....
Old 04-20-2002, 08:03 PM
TubaMan's Avatar
actually, the unit is rebuildable, just that most dealers are too lazy to do it. They have also been doing it that way for the last 10-15 years. all the hydrulic clutches are setup that way.
Old 04-20-2002, 08:18 PM
kutter752's Avatar
it has been a while since i have been into a newer tranny the only other one i have been in is my 83 Toyota 4x4.....sorry to sound stupid.....kind of new at this new truck struff just learning the electronic systems of these new things....
Quick Reply: Truck shakes when i let out clutch
