How to identify a 428 FE v.s. a 352/390 block
Old 04-30-2001, 04:42 PM
fordification's Avatar
Question How to identify a 428 FE v.s. a 352/390 block
I know this seems a little prehistoric relative to the other modern F-150 posts, but I'm looking at finding a regular 428 short block to replace my 390. I know the 428 is just a bored and stroked 390 block, but how would you identify one at a wreckers etc? I assume by the block I.D. number.
~'98 F-150 XLT Reg. Cab Flareside 4x4, Black, 5.4L, 3.55LS, tow package, 285/75/r16 Mud Terrain BFG's,K&N,WMS Velocity Tube, GTS headlight covers, Alpine changer w/FM mod, Clifford alarm system w/keyless entry & starter disable // Future considerations: Bed mat, tonneau cover, 4" suspension lift or 3" body lift.
~'71 F-100 Sport Custom Reg.Cab
-390FE w/Edelbrock Performer RPM intake, 780cfm Holley, ported & polished cylinder heads,
Hydraulic Crane Cam, 10.5:1 CR, Black Jack headers, true double roller timing chain, and high volume oil pump
-C6 transmision w/B&M 2600rpm stall
-9" Ford Rearend w/4.10 Richmond Gears & 31 spline axles
-215/65/r15 Yokohama's for the front & 28"x13.5"x15" Mickey Thompson ET Street slicks for the back, mounted on Centerline Auto Drag Lite II rims
Best 1/4 mile time @ 3500ft altitude 14.69secs @ 92mph
~2000 Suzuki RM125 Dirt Bike
-no need for any modifications! (yet)
~2001 Traxxas T-Maxx Nitro Monster Truck
Modifications: -180degree carb flip w/return spring installed
Old 04-30-2001, 06:26 PM
Isn't there any nostalgia fans out there?? There's lots of FE heritage in the F-100/F-150, consisting of the early 60's to mid 70's era of the F-truck. Anyone have any knowledge pertaining to this era?
[This message has been edited by fordification (edited 04-30-2001).]
Old 04-30-2001, 10:49 PM
dirt bike dave's Avatar
here is a link to a forum where you can probably get an answer.
http://network54.com/Hide/Forum/21142
Old 05-01-2001, 01:32 AM
Cowlady's Avatar
Exclamation
I remember coming across a site for classic Ford's using a search engine called google www.google.com . I don't remember the site address but maybe that will help. Also, try this site - http://www.ford-trucks.com/dcforum/97up/229.html & www.macsauto.com where you can order a free catalog specific to your vehicle.
Hope this helps! You can find me in chat every night so if you need more suggestions, catch me there after 9 or 9:30 DST. Bye!
www.andthensometoo.com/owners/cowlady
Love my truck & PROUD of it! If you can't beat 'em, you're NOT driving a FORD!
Shovies PROVE that FORD'S are #1!!
'97 Black F150 XLT ORP 4X4 Reg Cab/LB
4.6L/auto/3.55 LS/power EVERYTHING,
nerf bars, 17" wheels, fog lights, trailer hitch w/electrical connector, front tow hooks, bed rail caps,
6 CD changer, lumbar support & 3 cow license plates - so far!
[This message has been edited by Cowlady (edited 05-01-2001).]
Old 05-01-2001, 02:13 AM
JJ2000XLT's Avatar
If I remember correctly, all 427/428 blocks had 4-bolt mains. They had a different way of using 4 bolts on the main caps-2 of the bolts went through the side of the block. you can see this by looking at the side of the block.As far as I know none of the 390's had this setup. Good luck in finding one!!
JJ
2000 F150 XLT,Reg.Cab,LB,4.6,4R70W,3.55 F/D,Island Blue/Silver,Med.Graphite Int.,Keyless Entry,SRW,O/H console,All Pwr,CC,Ford soft Bed Cover,Sport Steps,Tow Pkg.,CD player,Prem.Cast Wheels
Old 05-01-2001, 02:42 AM
V10 man's Avatar
Pick up a copy of HP Books "How to Rebuild Your 352-428 Ford" It has all the casting numbers for the various parts and lots of other good info. I believe Ford quit using the 428 in 1967 when the 429 came out in 1968. Look for a 67 or earlier Thunderbird, Lincoln or other large Ford car. You can also mix and match crank, rods and pistons to make a 406, 410 or 428. The HP book will tell ya what works. Good luck finding a 428. They are rare. also check out www.ford-trucks.com
[This message has been edited by V10 man (edited 05-01-2001).]
Old 05-01-2001, 07:49 AM
redflare5.4's Avatar
Yes it will take casting numbers to ID the block.
Only the 427 side oiler blocks had 4 bolt mains.
The 428 continued into the 70 Mustangs
And the book you want is High Performance Fords.It's paperback and has 4 pictures of Ford engines on the cover.
Old 05-01-2001, 10:20 AM
Thanks guys! Redflare5.4, that High Performance Fords is a great book. I do have it, and read it yesterday. Except they don't mention anything about identifying the casting number on a 428 block. And my brother does have that book "How to Rebuild Your 352-428 Ford", but I keep forgeting to ask to borrow it again to look it up! Yeah, only the side-oiler 427 had the crossbolt mains. I sort of forgot about www.ford-trucks.com . I originally was looking into swapping my crank out with a 428 crank, except it requires purchasing 428 pistons that are shallower then the 390's, but the rods are atleast the same. I rather find a pre-assemble short block 428 that doesn't require any machining, and then I can bolt on all my goodies. A 428 crank with 15 over pistons would give me approximately a 414cid I think, which is fairly good, but I'd much rather have a 432cid.
Old 05-01-2001, 08:03 PM
I dont think you'll find a 30+year old shortblock that will not need machining!
You 390 block with the 428 crank 3.98"stroke makes the 410 engine that Ford had in the early60's.rods are all the same length.
Alot of the FE stuff fits everything except for the 427(big bore).
I love the FE engines,I had a 428cj I got from a junkyard in 1981 for $150 with the cj c6 trans!After about a $800 rebuild I put it my 67 Mustang oh what fun!Wish I never sold it.
Now for the present,believe it or not you could stroke a 351w to 392 very easily and put some modern aftermarket heads on it and make more power then the 428 will make for less money.Unless you can get a CJ from somebody for next to nothing.If these are not being collected the NHRA stock racers still pay good money for these parts.
Quick Reply: How to identify a 428 FE v.s. a 352/390 block
