Location of Flasher - 1999 F150
Old 09-01-2002, 11:29 AM
Zeahund's Avatar
Unhappy Location of Flasher - 1999 F150
I am driving my Dad's 1999 F150, Everything works - brake lights, hazards, front and rear lights, dash lights, but all four turn signals. I have replaced the fuses (13, 20) and the high amp fuses under the hood (cannot remember the numbers there), bulbs work - but checked for good connecttion. The parts store and Ford garage say the flahser. Any ideas where the flasher is? I know what it looks like but dang if I can find it. Searched the web and cannot find a replacement for it, so I am wondering if there is a flasher in the newer models?
thanks
Diana
Old 09-02-2002, 12:43 PM
kidtriton's Avatar
Its a yellow relay in the relay box with the blower relay, under the drivers side dash, towards the center of the dash. It is a relay and flash unit built into one.
Old 09-02-2002, 11:44 PM
Wino's Avatar
if your hazard lights flash. it's not your flasher your haveing trouble with. turn sig use same flasher. good chance you have a diff. problem. like multifunction sw. good luck
Old 09-02-2002, 11:46 PM
Wino's Avatar
it's fuse 13 and 23. but if the hazards work. those fuse's are good. sounds like sw. good luck
Old 09-02-2002, 11:48 PM
Wino's Avatar
it's fuse 13 and 23. good luck
Quick Reply: Location of Flasher - 1999 F150
