Torque specs for driveshaft flange (installing Drive shaft loop)
Old 09-17-2002, 10:12 AM
tallimeca's Avatar
Anyone know what the torque specs are , and tight and a quarter turn, untill you can't turn them anymore, or untill you feel the strain in your wrist and elbow doesnt' seem accurate to me.
Old 09-17-2002, 01:34 PM
superfords's Avatar
three blaps of the air gun
Old 09-17-2002, 01:44 PM
tallimeca's Avatar
DAMN IT!!!
I forgot about the air gun tricks too!!! No seriously, i thought that this would be one of those crucial points that you would want to make sure it was right.
Old 09-17-2002, 01:59 PM
superfords's Avatar
seriously though, the proper torque is 83 ft/lbs for the driveshaft flange to companion flange bolts.
hope this helps.
later,
chris
Old 09-17-2002, 02:04 PM
tallimeca's Avatar
thanks chris
you da man
Old 09-17-2002, 02:30 PM
Don's Bolt's Avatar
Hey Don
If you need the socket to remove the driveshaft I have one.
Old 09-17-2002, 02:36 PM
jarmstro's Avatar
Re: Torque specs for driveshaft flange (installing Drive shaft loop)
Be sure you use a 12 point socket too.
Old 09-17-2002, 02:55 PM
tallimeca's Avatar
not doing it
having the shop around the corner from me do it. Not enough room to move around for me under there. I went and got my inspection sticker today and they said they'd do it no problem. I should have them re-route my temperature sensor wire too while it's on the lift. Ordered my pulley today, but gonna be a while cause JDM is out of bearings.
Quick Reply: Torque specs for driveshaft flange (installing Drive shaft loop)
